I have an interesting problem with a circa 1940 Gibson EH-150. When playing through any input, at any volume level, there is a distortion that is sort of behind the note or chord. It's almost like having an overdrive pedal mixed in at a low level with the clean signal. You can hear it best after the initial hit of the strings. Even if you roll the volume on the guitar way down it still exists. I recapped (every electrolytic and coupling cap) this amp about 6 months ago for the owner, cleaned and tensioned the sockets, jacks etc. The weird thing is if I feed the amp a sine wave there is no distortion I can see on the scope. It will clip if it's cranked up enough, of course, and that looks normal, but at the same level the waveform looks clean at the output a guitar played through it exhibits this distortion.
I have tried another speaker, guitar, guitar cord, all tubes, replaced a few out of spec resistors and tried varying the frequency of the signal generator to see if the distortion was frequency dependent. I subbed out the field coil for resistors. I'm sure I'm forgetting other things I've tried. Any ideas? Thanks.
Dave
Dave
