I have behringer europower pmp2000 that would not power up so I took it a part and it has some burned resistors I want to start to repair the burnt parts I think I figured out the burnt resistors but the transistors Im confused because the part say's MJE5032G CQ942 on one and the other one says MJF150336 CQ945 but the board says 15033 or 10532? Any info on the parts and anything else to check please let me know Thanks
behringer pmp2000 blowing fuse
15032 and 15033 would be short form for MJE15032 and MJE15033. Are you sure that isn't what the transistors say on them? Post a picture of the transistors so we can see the numbers on them.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
If the drivers are toast then the output transistors are probably in no better shape.
2SD5200 & 2SA1973 are the numbers of the output devices.
If they are bad, make sure to check/ replace the low value (0.33 ohm) ballast resistors.
Also, the triacs on the Neutrix board should be verified still good.
(The triacs sometimes give there lives to save the speaker)Attached Files
I use FindChips.com: Electronic Components Search by Top Distributors as a first attempt to find semiconductors.
Yes, the 'big white ones' are the ballast resistors.
Most meters will have a tough time reading .033, so if they read anything low, they are good.
What you do not want is an open circuit reading.
The triac is on the Neutrix board.
(Oh what fun it is removing that)
You may be able to test it simply by going on the boards input (amplifier signal) leads.
They should show 'open'.
If they are shorted you will get a low reading on your meter.
Originally posted by Jam View PostThanks, I having a hard time finding the 5200/1943 parts? I sae Ebay have some but I don't trust that. Did they change part#?
You may have to replace them with more modern transistors.
My apologies, I had typed the incorrect output transistor part numbers.
2SC5200 2SC5200-O(Q) Toshiba | Mouser
2SA1943 2SA1943-O(Q) Toshiba | Mouser
