Hello,
I had a Bugera 1990 on the bench that randomly channel switched. After having read many accounts of failed regulators on the V22, I replaced the LM7815/LM7915 on the power amp board and the LM7805 on the DSP board. I also touched up any solder joints that seemed questionable on the various board. I ran the amplifier for three hours to ensure that heat wouldn't channels switch and no problems were apparent. Admittedly I didn't run it at full volume with a signal generator, just left it off of standby and played on it every fifteen minutes to ensure it continue to function.
The 1990 was returned to the customer and within 15 minutes of him playing at bedroom levels it began to channel switch again (always from overdrive back to clean). He did note that he could switch it on the front panel back to overdrive and it would function normally before shortly switching back to clean.
I am stumped and the lack of documentation on these amps makes it even more difficult. The only other information I know is that it had a failed 6L6 and was retubed with a quad of Ruby 6L6GCMSTR. I checked the bias with a probe and it was sitting at ~40mA per 6L6. Any recommendations?
Thanks in advance for any help,
Chris
Chris
