I'm repairing an SWR 750 watt bass amp. The power amp board will blow ( short) all 6 of the 2sc3264 Tanken transistors,
This only happens under load. without load, I can crank up the gain and volume to above 100v peak to peak. As soon
as i load the output ( resistive 5 ohm) it wil shortly blow all the expensive transistors. I've ohmed out or tested all
the transistors and resistors ( .1 ohm) in the power circuit. I can't find anything wrong. My next step was to leave out
the final four 2sc3264s and try with just the first two, and measure the collector current. Any other ideas? thanks
