I have a VOX AC30 CC2 on the bench. It came in with both the line and HT fuses blown. Bringing it up on the bulb tester revealed an intermittent flicker that suddenly flashed. I eliminated all the tubes, one at a time, replaced the four 22/450v filter caps, tried a new 5AR4 rectifier. The filament and 5v taps look to be OK. Thinking it looked good on the bulb tester, I switched it on, smack there go both fuses again. I lifted one side of the choke and the primary side V's look good. The problem seems to be somewhere with the secondary side, which feeds the screen V's as well as the preamp HV. I reconnected the choke and disconnected the preamp feed, no change. With two EL84's in I have a solid plate voltage, but pins 9 slowly charge up to not enough, and then slowly charge back down again. I have also tried a new set of EL84s.
So here's the question: can one bypass a choke to determine if it may be the problem? I had a choke in a Fender Twin make a fool of my years ago, not wanting to go there again. I am suspecting it is shorting during switch on, maybe causing a big enough surge to take out the fuses. Is there a better way to troubleshoot a choke?
Here is the drawing, it's page 7.
http://bmamps.com/Schematics/vox/Vox...05%29%20SM.pdf
