peavey_cs800x.pdf
The same thing happens on both sides, with the DDT switch on or off. With the level control maxed, the amp will put out about 14 volts with a 600mv signal in, with or without a load. As soon as the input goes over that level the amp drops out to no output. When I bring the input signal level back down to 600mv or less the output comes back. the power supply remains constant at about +/- 78 volts. Other than the board under the fan speed limiting resistor, R103 being kind of toasted looking, no signs other wise of distress. Amp looks clean inside. Is there a circuit that can shut down the power amp with a bad signal input?
