Well I am really having a bad time with this one. Sunn Model T reissue won't stop squealing. I have gone through the usual checklist and need a fresh insight! I have no more ideas.
I have:
- tried new tubes / swapping tubes
- cleaned and re-tensioned tube sockets, cleaned all pots with de-oxit
- tried a new input jack, and also cleaning and retensioning speaker jacks and FX loop jacks just in case
- made sure all pots and jacks are tight and making good contact with chassis
- tried bridging a capacitor over power supply and cathode bypass caps, even though they test ok for ESR and capacitance. Power supply voltages are about 10-15V low but I don't think this matters
- tried to find bad ground connections but have had no luck
- looked for bad solder joints at tube sockets and where the pots and input and FX loop jacks enter the PCB but no luck.
Basically the amp squeels at around 3.8K and it is not consistent. With something in the input jack both channels squeal. With no input only the gain channel squeals when you turn it up. When you pull the first preamp tube the squeal is gone. Coupling caps in V1 and V2 area seem ok via capacitance and short checks with a DMM.
From the looks of it this amp has never been worked on or even opened. The pre tubes are the original Fender branded "Groove Tubes" which seem to be a mishmash of Sovtek and JJs. The power tubes are semi-new Groove Tubes and are probably the only thing that has ever been replaced/worked on in the amp. From what I know it was bought off eBay, worked for a couple months and now squeals
Sorry this is a long post but hopefully it will save 20 questions and a long thread in general.
I have:
