Have a Marshall in at moment with 2 separate issues. It is a valvestate model.
1st problem - noise 1. On both clean and valve channels there is white noise after being switched on for about 5 minutes which I believe to be the resistors on the amp board so no real concerns with that one.
2nd problem - noise 2. On valve channels od1+2 only when volumes are pushed up to 7 and beyond there is a frequency tone (eg 1khz). When you plug a guitar in it goes away. Could this be a fault with the tube?
The white noise (1) is present whether or not an instrument is plugged in.
I had this amp in a month or so ago with the outputs fried which where replaced along with a few diodes. The amp, since then, has been used for 2-3 days a week since repair so not immediately suspecting original repair.
