Hi folks. My 1971 Super Reverb AA270 circuit, is slow to engage the vibrato. Only the first time I turn it on after the amp powers up. When I click the foot switch, it can take 45 seconds or so to start throbbing.
After that first initial engagement, it works fine. Immediately after I hit the switch it engages properly. Until I shut it down for a while, and caps maybe bleed down? Then it takes a while again to engage when
I fire the amp back up. I thought the tremolo was a little weak sounding compared to my 64 Bandmaster so I did change the roach. I also changed 2 of the small disc caps in the tremolo circuit. One was .01 , the other .02 uF.
The middle .01 sandwiched between those two I have not yet changed. Maybe I should? It was the hardest to reach, so I left it, just to see if the other cap changes made any improvement. The tremolo sounds the same,
as it was. Maybe just a little different design than in my 64 Bandmaster. It seems to work, probably like it should sound I suppose. Rate and depth knobs seem to work, maybe not as much depth adjustment as my 64 BM, but its
there. For example my 64 BM depth set at 5, sounds about the same as my SR on 8.5. SR vibrato is slow to engage initially as described. I had read somewhere that "slow to engage" meant
the caps in the circuit need replacing. Well two out of three caps replaced did not seem to fix anything. Maybe that one original .01 cap I left in there is the culprit? I also checked the resistors in the circuit with my DMM. They
seem to be in good range. I tested that remaining .01 cap with my DMM, it tested very close to spec.
Any other suggestions where to start next to fix the slow engaging vibrato? I am guessing a cap maybe, as it takes time to build up stored voltage? Maybe I should try another 12AX7 in V5. Have not done that yet.
Not sure. Still have lots to learn. I am no pro for sure. Just a hobby-ist with a genuine interest.
Thanks in advance.- Keith
