Hi,
i started here but decided to open a thread for having specific discussion about repairs and mods i made (or should make, please advise) to the Bolt-60 a friend entrusted me.
the standby switch position is corrected.
Old tubes are still making it but ... very tired (low volume power...) 5881/6L6WGC (instead of OEM 6L6GC) and a RCA 12AT7.
replacement tubes will be matched JJ 6L6GC pair (could you please tell me signification about sticker right side readings data ?)
and a balanced JJ 12AT7 (ECC81) for phase inverter.
Very bad job was done to this amp, most to the PCB but wait ... look at these 2 MKT capacitors added in a "beautiful technical specialist artwork..."
should have been made like this !
at same time and for the very low cost involved i soldered in a IC socket and replaced the CD4016 with CD 4066 (better specifications)
The "should be" 100Kohms next to the phase inverter tube was reading in ... Mohms so i replaced all 1/2W carbon compound resistor with 2W carbon film.
Maybe i should replace also the 600V capacitors and little tantalum blue one... but testing say they are ok so let's go as is.
Recap job of power supply board, all 1/2W carbon compound resistor replaced with 2W carbon film.
6,8K bias CC resistor replaced with 4,7K 2W CF in serie with 5K cermet 1,7W potentiometer (for external bias adjustment, i will add external banana 2mm for 1 ohm voltage test points)
Here are the 1ohm resistors between pin 8 off each tube and ground.
picture attachment number limit...
