hi,
i have a fender prosonic on the bench that i hope for some tips on. the pcb amps really make me appreciate the old hard wired builds.
the amp is noisy. it has a crackle and hissing with nothing plugged into the inputs and with vols turned to zero. i pulled the PI and the noise stops, so i pulled v1 noise still there, pulled v2 noise still there pulled v3 noise stops. the noise also stops when i break the contact at the fx loop jack.
with all tubes replaced i tested the leads for v3 (only 1/2 of v3 is used) with a signal tracer. 1, 2 and 3 are all noisy. there are 2 related relays on the schematic. without pulling the amp apart to access the bottom of the pcb are there any suggestions? i usually suspect a bad contact/solder connection but it seems these amps have some other pcb related issues from what i've read.
in advance, i really appreciate any help. i know modern builds require pcbs for economy, but they sure have their own set of problems and mysteries. with this one it looks like i have to really do allot of disasembly to even access the solder side of the board.
