So I am doing some work on a beautiful 1959 Fender Vibrolux 5F11 and I have two questions. First, the fuse that is in it currently is a 5A 32v fuse
, so obviously that is wrong. On the amp is says 1 amp fuse but does not indicate slo blo or fast. Also, on the schematics it shows a 2 amp fuse. Just need to know what fuse rating is best to put in it.
Secondly, I am attaching a 3-prong AC power cable. I am going to snip out the death cap and it's ground connection it attached to one of the screw mounts of the PT. I have always read that it is not good to attach my ground lug to the PT mounts. Also, I really don't want to drill a hole into this amp. So, I am thinking to attach the ground lug to the bolt that holds the chassis to the cab. This will allow the ground wire to be longest and last to disconnect if the cable is ripped out by accident. Any better ideas where to mount the ground lug? Thanks as always for reading and the advice.
![Thumbs Down](https://music-electronics-forum.com/core/images/smilies/icon_tdown.gif)
