I picked up a Crate V5 amp and the volume is quite low, even on 10 you can talk over it. It does overdrive quite a bit it just is not loud at all.
My first thought was a bad tube. I swapped in a new 12AX7 and an EL84 tube one at a time and there was no change. I tried a different 8 ohm speaker and it wasn't any louder. I pulled the chassis and took a good look over the circuit board and all the wiring. Every thing looks fine. I did an internet search for any Crate V5's with low volume. Not one showed up.
Does anyone have any ideas. Maybe a failed bias resister?
