Hey guys,
I'm working on a Peavey 3120 that's having a switching issue. Initially, the amp was worked on by a tech when the channel switch on the front of the amp was physically broken. The channel switch was replaced, and apparently channel switching was working, but the lead channel knobs weren't doing anything. Now I'm going over it, and it's definitely got some issues. With the switch on the middle RHYTHM position or LEAD position, the LEAD channel light is on. Putting the switch on the CLEAN position takes you to RHYTHM. Also, the overall volume is very low.
The switch wiring looks to be okay. When I plug into the Effects Return I'm getting a strong input signal. I've jumpered across the Send and Return with no difference. Can anyone point me in the right direction of where the problem might be occurring? It's seeming to be a preamp problem, possibly a relay?
triplex.pdf
triplex.pdf
