Originally posted by g1
View Post
Low volume in preamp stage
I made a punch list from my reply's, thanks
* (JM Fayhey) Bypass cathode resistors.
I had 22uf 35V caps on hand. Using three of them I bypassed R5, R30, and R13, cathode resistors.
This brought the volume up where I would expect a fifty watter to be.
It also introduced motor boating in channel 2 starting a about seven on the volume.
* (not that old, G1) Change grid resistors from 150K to 1meg.
I haven't done this yet.
* (Pedro Vecino) Value screen grid resistors 470K ?
Yes they are 470K's
* (Jazz P Bass) AC ripple on power supply nodes?
Yes I'm seeing 7V AC, at the first node right off the rectifier. And 1V AC at the second node.
The last two nodes were clean.
Hello Pedro,
The cathode resistor (R27) of the output tubes is a 150 ohm 10 watt. Volts there are 25V DC.
BTW, I found changes in the motor boating on Ch2, when I probed it with a chop stick.
I resoldered all the joints on that board with no results.
I could increase and decrease the oscillation with lead dress.
I found a touch sensitive cap in the tone stack against the circuit board, and pryd it clear and the motor boating instantly stoped.
I redressed the leads in the other channel just for fun.
So far it is sounding really good.
Originally posted by Realist2 View PostWhat would you think may be preventing the tubes full amplification in that first stage Enzo?
Originally posted by Pedro Vecino View Post25V : 150 Ohm = 166mA
166mA : 2 = 83mA
83mA x (390-25V) = 30 watts/tube
I've never seen a setup like this with low cathode resistor and very high screen grid resistors. Some objective should pursue..
I don't think they could be 470K either. That would be like leaving the screens disconnected.
I think you would find they measure as 470 ohm, not 470K ohm.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Another problem with this Schematic that I didn't catch.
I have two of these amps and I know my 69, has 470's in it because it came with none.
Glen at Mars Amp repair in the post "Montgomery Wards squealing" back in 06, said to add the 470's, which fixed the amp.
I didn't have the schematics at the time.
I'm becoming curious as to who drew up that schem... it's CLEARLY an attempt to stop the cloners by intentionally filling it with "mistakes..."
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
What do they measure with an ohm meter?
Is this the amp that has 25 volts at the cathode resistor?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Maybe they are not wired up like the schematic shows?
What is the voltage at pin4 of the power tubes?
Have you tried raising the value of the grid resistor of the first triode yet?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
