Greetings to you all. My current conundrum is a Boss TR-2 Tremolo pedal that I rescued after someone did some very crude modding to it. I opened it up to find all of the mechanical mods done with solid thick gauge wire and electrical tape. It's the old 4 IC version and the following mods were done:
C7 - cut from board (I've since replaced it)
R31 - removed from board and wired into a switch with a 250k potentiometer
R19 - replaced with a 6.8k resistor
Even in bypass mode you can hear the ticking of the oscillator, which I've confirmed by changing its speed with the rate knob. I Googled my brains out on this topic and found a few pages worth of good info, but in regards to this particular issue I only found a page that suggests swapping out the op amps or adding a resistor/capacitor to IC4. I know the TR-2 has a history of being noisy, but even in bypass mode? Seems odd. Whether it's related to the mods done to it, I can't be sure...
Thanks for any and all help, as always. I missed you guys!
Hope this finds everyone well.
