I've been playing with this amp on and off for a while and here's where I'm at...
The amp is a 70's V4 with what looks like a replacement transformer and a half power switch. (I didn't install either of these, it was bought like that)
I've done the following maintenanceto it:
-proper ground.
-replace out of spec resistors and all electrolytics on the circuit board.
-install bias trimpot
-replace leaking silver Mallory 20/20uF cap on the inside of the chassis with a Sprague 40uF.
-new 6A fuse
The issue I'm having is that the amp is breaking up at just about 3 on either channel. I notice that if I play with the controls, I can get the breakup to be slightly less (for example, the mids pot acts almost like a gain control when the volume is at 3).
The amp is running a quad of TAD 6L6GC's and biased at around 36mA.
The 3 yellow filter caps are still original.
I have read a few posts saying that the V4's from the 70's started breaking up at around 10 oclock on the vol dial, but I've only owned V2's, so I can't compare.
The half power switch doesn't change anything regarding the breakup...only reduces the overall volume by a few decibels.
The TAD's are new...could it be the powertubes?
Is it worth playing with preamp tubes?
(I should note I'm testing with a 2x12 cab with WGS ET90's.)
I'm looking for a little help/guidance. I included a few pics if it helps.
-proper ground.
-new 6A fuse
