One of the staff members brought me a friend of his' SWR Studio 220 Bass Head for repair. I was told it didn't power up, but it came up just fine. What also came just fine is a 5khz oscillation, when the Treble Control is Pulled out into it's Transparency' position, and set anywhere from 12 o'clock or higher, Master Vol anywhere from 12 o'clock and higher, Gain anywhere above 3 o'clock, and the Aural Enhancement anywhere above CCW.
These are built as poorly as the SM400. Nothing I really care to have to work on, but, I agreed to take a look at it. I first replaced the 12AX7 preamp tube, as the one installed also had a nasty white noise problem, alternate tube got rid of that. I tried a 12AY7...a bit less gain, which dropped the oscillation level, but didn't remove it. A 12AT7 lowered it more, but also didn't remove it. Tried swapping out the TL072 BiFET op amps, with no success. Tried some slower dual op amps.....around the Treble Control stage, where all the EQ's pots are common, as well as input stage, output stage, etc. Couldn't kill it with swapping IC's out...didn't expect to, but easy to get at. I did NOT see any evidence of power supply bypass around any of the op amps, unless tack-soldered on the rear side of the PCB.
So, reluctantly, I pulled all the pot knobs & hardware off and front panel off in order to gain access to the bottom side of the PCB. Really built like kaka as far as servicing goes. Added 0.1uF/100V mono caps across all the op amp supply connections to ground. Had serious doubts that would cure anything, but.....they should be there anyhow. As expected, that made no difference at all (had put the board and hardware back together, so there was solid connections and grounding of the panel, jacks, etc.
The biggest offender appears to be the Transparency control....but, even leaving that control dis-engaged, I can dial up oscillation by turning the Master up along with the Treble up. Turning the Gain down, Master down a touch, Treble down a touch, Aural Enhancement down all the way will kill the oscillation.
I didn't find any solder joint issues on the bottom of the PCB, all connections appear ok It behaves as though 5kHz oscillation is designed in.
Anyone run into this issue with this model, or the SM400, which is very similar? Presently sorry I ever said yes to service this horribly built amp.
