I received the flagship of the low end Marshall Line in for repair and thought I would post my findings.....This was supposed to be cutting in and out but the power is fine.....It turns out that there is a high wattage black resistor which has broken away from the ckt board......which was the cause of no sound......so I soldered the lead back to where it was supposed to go and that was it...apparently this problem happens alot with this particular Marshall line......Also, when installing the nuts on the controls....only put them hand tight....if you tighten them too much you will break the wafers inside the pots...hope this helps somebody out.................
Cheers,
Bernie
P.S. The header should MG and not MF
Cheers,
Bernie
