Hello.
I'm troubleshooting the switching circuit of a Fender Hot Rod Deluxe.
The problem is that after a while it's not possible to switch from drive to more drive, the led stay yellow and doesn't turn red.
I've checked the test point as suggested on the schematic by Fender; here what I've found.
TP31
Normal 1,4V
Drive 1,13V
More Drive 1,11V
TP32
Channel Select Out 0,52V
Channel Select In 9,89V
TP33
Normal 16,6V
Drive -10,53
More Drive -13V
TP34
Normal -11,8v
Drive -11,75v (Slowly Increase)
More Drive -4,5v
TP35
More Drive Out -0,535v
More Drive In -9,96v
TP36
Normal -16,18v
Drive -16,18v
More Drive -16,18v
I've replaced all the trannies, mosfets and zeners.
I got a steady +16/-16 from the power supply.
Now I'm running out of ideas.
Greetings From Italy.
TP31
Normal 1,4V
Drive 1,13V
More Drive 1,11V
TP32
TP33
Normal 16,6V
Drive -10,53
More Drive -13V
TP34
Normal -11,8v
More Drive -4,5v
TP35
TP36
Normal -16,18v
Drive -16,18v
More Drive -16,18v
