I have a Peavey Classic Chorus 212 that does not switch to the drive channel. No footswitch but does not change channels when using front panel switch. Power amp and clean channel work fine. 706.pdf
Peavey Classic Chorus 212 channel switching problem
Agree, Q4 is the ground path for the switch, when there is no pedal. You can short the collector to ground to test the circuit.
R61 is a pullup resistor to +15v for the base. However, you won't see +15 on the base, or at least you shouldn't. You should see more like +0.5v, the base-emitter junction voltage.
If that is OK, and the switch actually works - check it with an ohm meter - then see if there is 15v on the relay diode CR15 - on both ends, and also check if R171 is open.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostR61 is a pullup resistor to +15v for the base. However, you won't see +15 on the base, or at least you shouldn't. You should see more like +0.5v, the base-emitter junction voltage.
