Odd,
when you turn the master output power level dual pot up slightly the output section starts oscillating some nasty low frequency square wave.
Power supplies all look good, nice clean signal getting to the output amp chip until the pot is turned up a bit.
Anyone replace the IC4 brick on one of these?
It's an SSTK404-130S, one like you'd find in a home stereo.
I swapped out the preceeding IC3 dual op amp with the same results.
