Hey guys,
I have a Deluxe Reverb (silver face, converted to AB764 with the original 5AR4 still in place). I measured all of the voltages to compare to the fender schematic and nearly all of them were 10-20% higher, but the voltages on the vibrato section are -way- off.
All the other voltages being 10-20% higher, I'm guessing that's maybe to do with higher wall voltages (Around 125VAC here)? But the vibrato voltages I don't understand (392V at one plate instead of 270, and 443 at the other instead of 345. At the cathodes I'm only reading +0.1V as well instead of 2.1 and 17.0.
Attached is the schematic with all of the voltages.
Also attached is a scope shot of the amp going into an 8 ohm dummy load. The blue trace is the amp's output with a 440 Hz test tone, and the yellow trace is the vibrato oscillator (tapped off of the speed pot). Speed is low and intensity is at max. I can't help notice that the tremolo isn't smooth, it is mostly at max volume, with just a very quick dip in volume and an even quicker rise back to full volume. The oscillator itself looks to be pretty smooth, and reasonably sine-wave-ish.
FWIW, the amp is biased at 68% idle dissipation, power tubes are matched and an extra capacitor has been tacked onto the LDR as the standard Fender service bulletin "tick fix".
