hello a friend has asked me to look at his fender ultimate chorus SS amp.
diagnosis was that Input 1 was not working
Channel 1 is giving low volume. Channel 2 was working fine.
I replaced the input 1 jack and now its working
I also replaced the 2 4700UF 50v capacitors however channel one is still giving low volume and now the amp is cutting off after a couple minutes use. A few minutes later it will be able to power back up.
confirmed fuse is still in tact and heat sink is back in place.
any advice on where to go from here or any troubleshooting steps or common causes for channel 1 to be out?
All solder points look ok and nothing visually obvious. Turning the channel 1 eq pots seem to momentarily flicker the channel back in to use but i've used detox cleaner on them but hasn't made a difference
thank you in advance.
