I am experiencing such a strange phenomena.
I have a V4 that only works on my bench. On any other outlet it immediately blows the fuse when the standby is flipped. On my bench it works perfect, I've turned it off and on 100 times no problem. Puts out proper power and PS voltagees check normal. On another outlet it will blow the fuse every single time once the standby is flipped. It has done this in a practice space, home of the owner, and also on various other outlets that are in my building but not on my bench. I don't understand what's special about my bench. Even when I bypasss everything on my bench and plug directly into the wall it works fine.
I have run the amp through a bulb limiter to try to sort this and have found a few clues.
- The short comes after the PT, with both HV and filament secondary disconnected it does not light the bulb. Re-attach filament winding and no short. Re-attach HV winding and bulb lights brightly.
- When I turn on the power you can hear a buzz through the speakers. How is this possible if the standby is not engaged? In the past I have experienced an Ampeg V2 that did this and was mystified but it worked normally on my bench and other locations as well.
- When the short happens it ALWAYS blows diode D5. Occasionally it blows rectifier diodes too but not always. A lot of good 1N4007s have gone down in this battle
- I have re-capped the power supply but cannot find a discrepancy. Maybe I am missing something. STilll have never experienced something that only works on certain outlets and catastrophically fails on others.
I have checked the wiring against my V4 from the AC outlet up to the PT secondaries and it's exactly the same. Any thoughts? I'm at a loss for now.
