Also, measure the current with signal - does it have a little or no fluctuation or a large swing in current ?
Ugly distortion with tube amp when you play
Originally posted by TigerAmps View PostAlso, measure the current with signal - does it have a little or no fluctuation or a large swing in current ?
That looks OK for idle; what about when you apply signal and turn up the volume - how large is the current fluctuation?
I use a bias probe to get a feel for what is going on ....
Also, can you swap out the OT for a known good one, just to rule out the OT
Interesting circuit as it deploys two cathode follower stages. Have you checked that the correct tubes are in place, the phase splitter is a lower gain ECC81. I would check the voltagess working back from the output tubes, check the bias voltage to these tubes and that the control grids each have the same amount of bias supplied. If these measurements appear normal then go the phase splitter and check the anode voltages which again should be equal. If all voltages appear OK then the trouble shooting becomes a bit tricky.
A CRO is a great tool but unless you understand it's short comings and also have a calibrated/adjustable low distortion audio signal generator it may not provide any real answers at this stage in your trouble shooting. A 10mV signal at 1Khz would be required to utilize a CRO, first set to a sine wave signal and then set to a square wave signal, but I'm getting ahead of myself.
Good luck and keep us posted. Mickey
Originally posted by Ampzone View PostThis helps, so far the wave looks normal around V1 after that around V2 it starts to look jagged or hacked off so to speak around the 220pf cap around the treble pot. It is not longer an even sine wave. Now maybe this is normal? for this type amp. Now with the audio probe plugged into an external amp I get signal all the way to the grid stoppers on V5-8 pin 5 input. The sound is the 1k tone and not unlike the earlier stages."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by The Dude View PostIs it possible you could post pictures/scope shots of what you are seeing? What you describe seems like a potential issue to me. IMO, although I'm not saying an audio probe doesn't have its uses, a 1K tone can be pretty distorted before your ears actually pick up on it. I'd much more trust a visual representation of what's going on.
I will try and get some shots in the AM. The tubes are set to the right arrangement. I have a 50w ot I could try to rule out a bad ot, but I am not sure that is ok.
The primary readings on the OT are under 20ohms, that I can say and the primary to ground is in the high MEGs.
