Folks,
I got this amp in the other day and customer complained about the amp had blown the mains external fuse. When he replaced it, still nothing. He replaced the power tubes. He didn't realize that there were three fuses inside as well.
I found the 8a filament fuse and the internal mains fuse blown. I determined that one of the 1N4001 diodes in the bridge had shorted so replaced that and replaced both blown fuses. Turned amp on and all was well.....until the customer got it back. He went to turn it on and no lights and tubes didn't light up.
I got it back, and found that the 8a filament fuse had once again blown.
I measured surge current as best I could (digital meters are pretty slow) and it kicked to almost 11 amps when turned on cold and then came to rest around 5.2 amps. I did the math and 5amps is about right for six 12AX7's and four 6L6's, I have a 10 amp fuse in there right now and when I turn it on from cold, I can see the filament in the fuse glow red for a few tenths of a second.
Is it possible that one or more of these new power tube's cold filaments could hog this much current?
