Source for Reverb Tank Transducers?
  • Source for Reverb Tank Transducers?
    Does anyone know of a source for just the reverb tank transducers? I know the labor to repair a tank is more than just buying new, but I am looking to customize to get a three-spring tank configuration that is not available new. Thanks, Chuck
    Do you need a specific impedance value?
    Turn it up so that everything is louder than everything else.
      As you inferred, the transducer would not be much less than the cost of some of the current tanks.
      Why not mix and match parts from a couple cheap MOD tanks?
      What exactly do you need?
        FWIW I make my own reverb tanks from scratch, but there is one component you won't easily find: tiny hollow cylindrical magnets, think hollow pencil leads or plastic ballpoint ink tanks cut in 1/8" lengths size; they must be hollow so you can epoxy a piece of .008 guitar string through them, which will twist the delay springs.
        I had to order my own ferrite magnet dust pressing dies and then have some 5000 "cooked" at a magnet factory, the minimum order they would take.
        So for a prototype you might experiment with parts recycled from dead tanks.
          I need 150 ohm input.
          I'm trying to make what would be a 9BB3C1D for a TSL100 head - 3 springs and long decay. AES/CE sells an Accutronics 9BB2C1B - only medium decay and horizontal mount (I could make that part work by moving it to the top).
          You guys got me thinking - I might have an old 4BB3C1D in my pile of dead reverb tanks. If I remember correctly, the output transducer is always the one that goes bad. I will check and see if I have one and if the input is good.
            Originally posted by telecaster View Post
            ...horizontal mount (I could make that part work by moving it to the top)...
            The mounting orientation I easy to change by rearranging the suspension springs that hold the inner tray to the tank's outer case. That's why there is that pattern of multiple holes.
              You can roughly estimate the coil impedance.
              Measure the DC resistance, and also calculate the Reactance at 1khz (using inductance)
              Then Z=√[(R*R) + (XL*XL)]
                You won't fit 3 springs onto a 2 spring transducer .
                The delay length is a function of the spring length/guage.
                A 150ohm impedance input transducer will read approximately 25 ohms DC resistance on your meter.
                You'll need springs from any 9xx3xxx tank to get long delay.
                Input & output transducer from any 9BB type tank.
                Parts will not be interchangeable with different brand tanks.
                See attached for numbering system info.
                On a side note, some info on TSL reverb drive revisions here: Marshall TSL 100/122 reverb driver revisions | Electronic States
