5E3 MM PT question
  • 5E3 MM PT question
    Hi All
    I have just finished a 5E3 from scratch following as possible Fender schem and layout except for Cathode resistor 270R instead of 250R and 4,7K instead of 5K for first dropping resistor.
    Based in France I am using 230VAC from the wall, a FTDP/240M Mercury Magnetics PT (380-0-380) known in MM as stock B+ is install and wired to 230VAC for primary (Multi tap Primary PT).
    Here are my voltages with a 5Y3GT from Sovtek.
    B+ at 5Y3GT output 416 VDC
    After 4K7 resistor 379 VDC
    After 22k resistor 276 VDC
    6V6S (JJ) Plate 403 VDC
    Pin8 6V6 26,8 VDC
    It seems to me that voltages are to high maybe because of PT output?
    And of course 6V6 are biased very hot with this values.
    What is the best solution to reduce voltages?
    1 Swaping to a real NOS 5Y3GT to decrease B+?
    2 Changing 4k7 to 5k1 (or more) dropping resistor value?
    3 Or maybe another solution?
    Thanks a lot to take time to help me
    Best Regards
    Phil
    A NOS 5Y3 will help quite a bit...
      Try measuring your wall voltage - over 230? What's the heater voltage? Is the HT secondary reading 380-0-380? If these are higher than expected then try connecting to the 240 tap and see if that brings the readings into the range you were wanting to see. It will not stress the transformer - as all the voltages will be lower it will actually be less stress on it. Good luck - Peter
