I wasn't sure if this should be posted in "theory" or "troubleshooting". Well... I chose one.
I have an amp on the bench that suffered a reverb oscillation when the reverb volume was set over 3/4. An actual circuit oscillation presenting as a high pitched whine. Not an acoustic feedback. At first I tried all manor of top end bleeders at different points in the circuit. I narrowed it down to the net gain of the output being the trigger but nothing I tried would stop the oscillation short of a cap to ground so large in value as to be unacceptable. I checked grounds for both integrity and best location. I was just about pulling my hair out as I was moving the pan around to see if by some odd chance it would help. And as I was doing this I layed my hand on one of the speaker baskets and the oscillation stopped! So... Grounding the speakers at the basket or the magnets would stop the oscillation. This amp has two speakers and the oscillation occurred with the pan on either side of the cabinet unless I grounded that speaker. With one speaker grounded, if I scooched the pan near the other speaker the amp would oscillate. I could have just grounded one speaker and left the pan on that side, but I grounded both just cuz.
Interesting observations...
This amp has two different type speakers. One G12H30 and one Vintage 30. The G12H30 has a resistance between the magnet assy and basket of over 100k. The V30 has a resistance between the magnet assy and basket of 7 ohms. Yet grounding either the basket or the magnet assy on either speaker would stop the oscillation. I grounded both baskets.
Using a capacitor of only .022uf in the grounding lead would stop the oscillation. I just used a lead wire from the basket to the negative lead of the spider with no cap, but I did experiment.
Wrapping the dual RCA reverb pan cord around the lead from the amp to the speaker ALMOST stopped the oscillation (did I mention I experimented ).
My reason for posting is that I would like to better understand what I've observed. The problem is solved, but why? And why did it happen in the first place?
