Just picked up one of these from eek!bay and began testing it out. It came without speaker or tubes (as promised), but also came with evidence of one helluva drop (not promised). The PT mounting tabs are bent and the presence knob is bent out of alignment, still turns though. Once I got tubes, I put it one a lightbulb limiter and brought it up. Off the limiter now.
The clean channel makes a popping, crackling noise. I tried turning every control, nothing affected the noise. Well, maybe the presence control took a little HF out. Noise with ALL controls turned fully down. Finally I pushed the drive channel button. Dead quiet. I had to plug in a guitar to see if the drive channel worked at all!
The amp works, drive channel has only the hiss expected from turning up the gain, clean channel works but has the noise on it. With the noise audible when all controls are down, and is affected by the channel switching, should I be looking at the control voltage circuitry? Do LDRs go bad and make this noise? I appreciate any and all comments.![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
The schem can be found at this site Fender Super 60 | Ampwares
