I'm working on a Hartke LH500 with no output. I've narrowed it down to the protection circuit, but keep hitting a wall. When you power the unit on, you can occasionally get the relay to switch if you tap the board. Thinking that the relay was sticking, I replaced the MIH-SH-124L with an OMI-SH-124L. Problem remained the same. Then after reading an older post from Enzo, I replaced C316, C317, and C318, which are inline with the TA7317. Still no go. IC301 is a small daughterboard with a bunch of SMD components. I'm wondering if the issue might be there. Does anyone have any insight on these?
LH1000 v3.8.pdf
LH1000 v3.8.pdf
