Ok - I have a Twin Reverb that I recapped several months ago. It has worked well for me for several gigs but this past weekend it made a loud pop and let the smoke out. One of the 100uf filter caps had exploded. It turns out I had one of them in backwards. How I made it through a half dozen gigs is beyond me, but I did.
Anyway, I ordered two new caps. I replaced the one that blew up and fired her up. Immediately blew the fuse. I checked the rectifier diodes and they checked out. I also checked the 220k resistors that parallel the filter caps and they are fine. I replaced the other filter cap but that didn't help. This is all with the standby switch off btw. The transformer checks fine (no shorts between windings). Also, if I disconnect the two transformer leads from the rectifier section I can power it up, not blow a fuse, and read proper the proper AC voltage across the transformer leads. There's another 48 vac lead that I left connected and I had the proper voltage there. So it seems to me like the problem is in the power supply (since the standby switch is off). Oh, I also removed the two filter caps and fired it up and the fuse didn't blow (again, standby off).
So now I'm wondering if I've got a bad filter cap. I can charge them with a 9 volt battery and watch the voltage slowly drain off with my multimeter conntected. Other than that, I'm not sure how to test them.
So...any suggestions on what else to test? Any way to test the capacitors beyond what I tried? All I have is a DMM.
Thanks,
Jim
P.S. - I have an associates degree in Electronics Technology...but that was from 25 + years ago, so my theory is out the window, but I know how to not kill myself.
Thanks,
Jim
