A customer's Hartke A100 amp was motorboating. When the amp was relocated from the rear to the front of the house, all was quiet. It turned out that he had Ethernet over Power adaptors plugged into the room next to where the amp was. I have heard that these can cause problems with RF devices such as ham radios, but I haven't experienced audio gear being effected before. I believe his Fender Bassman 200 was affected as well. Does anyone know of any line filters available to eliminate this?
Interference from EOP devices
Grab any of those FILTERED outlet strips as used for computers. See if it makes a difference.
And get an outlet tester to make sure the outlets in the affected part of the house are properly wired.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostGrab any of those FILTERED outlet strips as used for computers. See if it makes a difference.
It certainly has not been proven that the EOP devices are the cause of the amp problems.
As they operate in the Mhz band, it is hard ti imagine how that could make a linear power supply, Cklass A/B amplifier 'motorboat'.
http://www.quora.com/In-a-nutshell-h...-adapters-work
It may actually be a problem in the two amps. (failing smoothing capacitors)
A more systermatic approach would help prove the cause.
Aside: if it is a new house, why did they not run Cat5 cable?Last edited by Jazz P Bass; 06-19-2015, 01:52 PM.
And get an outlet tester to make sure the outlets in the affected part of the house are properly wired.! Anyone else here ever been shocked through the lips? I picked up an outlet tester very soon after.
Many years ago, our guitarist lifted his axe up while playing, the high E string touched the microphone and burned in half. BZZZZT.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Jazz P Bass View PostIt certainly has not been proven that the EOP devices are the cause of the amp problems.
In a nutshell, how do ethernet over power line adapters work? - Quora
Originally posted by Jazz P Bass View PostI would consider a wireless router.
That EOP is great for 'home automation'.
But I would not want my data on a 120Vac power line.
EOP is nifty and neat solution - I use it to put another wireless router up the other end of the house.
Was there anything plugged in to the amp when it was motorboating - eg. guitar lead, effects leads? If not, then was the motorboating related to some part of the amp (eg. before the vol or tone)?
I guess the other diagnostic would be if you were able to unplug the EOP devices at the time of the motor-boating to provide a higher confidence of directly correlating EOF with the motorboating.
It certainly is an interesting example of what may be external interference.
Originally posted by gui_tarzan View PostBecause everything is moving to wireless. Cat5 is so 2010.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
Originally posted by R.G. View PostYeah! Twisted pair is so old-school. My house is all Cat5 wired, so it's hard to get a connection, have to plug into a wall outlet. Sometimes it's easier just to select one of the three neighbor's wifi's that I can pick up and use... and watch their traffic... etc.
Laptops, fegetaboutit.
Quote" Sometimes it's easier just to select one of the three neighbor's wifi's that I can pick up and use."
Your neighbors don't use security settings?
