Hi all, a little stumped here. The amp fires up, and has a good bit of ambient hiss/hum, and if I plug into the power amp in, I get a good bit of output, so the power amp works.
If I plug into the front of the amp and play, I only get a trickle of staticky sound if the preamp volume is way up.
Plugging into the front and taking a signal out of the effects send, I get a nice strong signal. Plugging into the effects return, I get nothing, so I think the problem is in the tube stage after the effects return.
All resistors around V3a measure out, and I'm getting about 350v on the plate, and it makes a hellacious loud pop when measuring. Could it be the relay? I am not familiar with them or how to diagnose/check problems with them.
schematic------> http://www.hartsafire.com/classic400..._service-1.pdf
