Which model Boogie is this?
  • Which model Boogie is this?
    1x12 combo with reverb, the fancy wood and cane front.
    Two 6L6, 5-12AX7, on two separate boards.
    Similar to a MKI or II with no EQ.
    clean channel and overdrive channel with lead gain, lead master, tmb, reverb and presence on rear, loop jacks hidden under chassis, all stuffed in a little cabinet.
    None of the schems. I find quite match up.
    No hard fault, just lacks "singing overdrive" from lead channel according to owner.
    One coupling resistor "looks" to maybe have been changed to mellow it a bit.
    You know when they use a 3.3M with like A 10pf in parallel between stages, the pf is gone.
    Is there anything written on the end of the chassis in marker? Mesa offered the cane front cabinet in several models.
      SR 46 written in marker on both sides of the chassis.
      No other indications of a model number.
      Judging by the PC boards and parts it's an older unit, not a reissue.
        What is on the end means something, but I do not recall the code.
        This may help:
        https://en.wikipedia.org/wiki/Mesa_Boogie_Mark_Series
        Somewher I had a list or which controls had pull switches on which Mark series models.
          Right, it has the same layout as a MKII A or B, but those schematics don't match.
          I'll do some more searching, just thought I'd ask here.
          Thanks.
