Recently picked up a The Twin that needs some work. I was told one of the output tubes, V5 was red plating.
I found one bad output tube at v10, also two bad preamp tubes.
On V5, I notice that the 1.5K 1/4 watt resistor at pin 5 appears burnt although it reads ok on a DVM. The 470 1 watt resistor at pin 4 is cracked but also reads ok on the DVM. I plan to replace both of these resistors.
On V11, the 470 resistor at is reading around 660 ohms, while all the others are close to 470. I will also be replacing this resistor as it is out of spec.
I was wondering if I need to stay with carbon resistors for the 470 1 watt? I only found a ceramic replacement doing a quick search on Mouser.
Thank you. MC
Thank you. MC
