Have the problem with Fender Passport 500pro
  • Have the problem with Fender Passport 500pro
    Help me identify an elements # U603 and # U605 on the main board. The shell of this elements is destroyed and I can't find anywhere a list of spare parts or service manual for Fender Passport 500 pro
    Your best bet is to contact Fender & request the service manual.
      You may need to call Fender to find out. It's not the sort of amp that will have a schematic just floating around on the web. Fender may refer you to a qualified service center. You may want to go with that. If "The shell of this elements is destroyed" there is likely a reason this happened that goes beyond gross component failure. Whatever caused the destruction of that component is what needs to be addressed. The repair probably isn't as simple as just replacing the exploded parts.
        Yea...probably you're right.
        I don't thinking that it will be easy)
        Thanks to all!
          I'm not in the shop today, but the last time I had one of these in under warrantee, the power amp was dead and was a board swap from Fender. I don't even know if we have a service manual for this one or not.
          Maybe Enzo will have one.
            Even if fender wants a board swap under warranty, they still will have schematics and part lists etc. Whether they give it to you or not is a separate question.
            I have the PD-500, I don't have 500Pro. I don't see a U603 and 605 in the PD-500 list.
