Hi all, i have a Wharfedale TCT100 100w all valve head running into a hand-made 2x12 celestion cab. The head is a bit of a rare beast, i dont think very many were made, they were later re-branded and now sell as Albion amps. I've been gigging the amp regularly for about 4 years now and had no problems at all until last night...
towards the end of a 2 and a half hour set, the amp started cutting out.. to be more accurate it lost volume considerably and the sound was weak and distorted (not in a desirable way, more crackly/broken sounding). I play through a distortion pedal and a wah as well as running a multi-effects through the send/return loop on the amp, so i bypassed the wah and distortion and plugged my guitar directly into the amp although i forgot to bypass the loop on the amp (gig pressure!). Still, the sound was the same... it seemed ok for the first few milliseconds of hitting a note on the guitar but would then immediately go quiet and broken-up. I'm fairly used to the sound of dodgy cables and the like and i'm as sure as i can be that this was an amp problem... besides which i ended up plugging the guitar into the p.a. to finish the gig and there were no signal problems there.
Have spent today testing the amp with my usual gig setup... played it for 2 hours at gig volume, left it on for several hours, came back and played some more... absolutely fine!
As i say, i've gigged this amp a lot over the last four years, it's been in some very tight spots, left on for hours, played at high volume and i've never had a problem. Now i'm paranoid it's going to happen again next time i have a gig... and i have no idea what might have gone wrong!
Actually come to think of it there is one slightly odd problem i've had in the past, but hasnt happened for quite some time now - the amp sometimes used to hum audibly through the speaker output on turning it on, kind of an interference sound with a certain amount of hiss as well although it remained constant while the guitar signal was fine and could be turned up to mask the sound. i usually found this went away after the valves had warmed up or after a judicious "tap" on the back of the amp. I should also mention that when i first got the amp, being a total newbie to head/cab configurations and having always played combos, i very stupidly was using two instrument cables for the speaker outputs!! Once i had burned out a few of these i realized my mistake and got proper speaker cables and all has been fine since.
Any thoughts, opinions or suggestions would be most welcome, cheers
PS have visually checked the valves and although i'm no expert they certainly seem fine, i'm not getting the characteristic crackle of dying valves anyway - been down that road before with my old laney vc30... the valve sockets seem sturdy enough, valves are all solid and look to be in pretty good shape although they all say made in china... except one sovtek in the input stage that i think previous owner must have put in, not sure how reliable chinese valves are considered to be?
