Hello All
I have a Laney VC30 I am trying to fix. It stopped working when the user replaced valve. I found 470 ohm 5W resistor in HT line feeding plate of preamp valves and screen for EL84 open. The amp started working once resistor was replaced but
Wonder if anyone can please help.
Schematic can be found here:
http://bmamps.com/Schematics/Laney/L...30_pre2008.pdf
Thanks in advance.
- it still has lots of crackling and popping sounds. At times it gives out a hum like one of the supply rail is shorted.
- The screen dropper resistance shown on schematic is 100 ohms but in this amp it is 82 ohms, I am not sure if it is a mod done by someone or is it design change by Laney
- The HT voltage is much higher than 290V shown on schematic. It is about 350V
Thanks in advance.
