Hello,
I'm trying a project that is pushing my level of understanding of tube amps. I have a Rex branded Valco 6143 amp with 8" speaker and 4 tubes (35Z5, 117Z3, 50L6, 12AX7).
I have an isolation transformer (N-68X Transformer; Isolation; Pri:115 to 230VAC, Sec:115VAC; 50/60Hz; 50VA; 1500Vrms) that I plan on installing to keep from killing myself.
What I don't understand among many things is why there are two 1/2 wave rectifiers in this circuit. I have found a schematic for the Valco 6143 that is identical except that it uses a 35W4 tube instead of the 117Z3. The 35W4 seems to be similar except it can take higher voltages.
I have seen some amp conversions where they install a full wave solid state rectifier between the isolation transformer and the 35W4 to symmetrically load the isolation transformer.
Can anyone explain to me how this amp works and why it has two 1/2 wave rectifiers and what the best way to install an isolation transformer?
Thanks,
Dave
valco-6143-amplifier-schematic.pdf
Thanks,
Dave
