I got a Redmere Soloist in for repair and restoration and it was in pieces... not all the pieces however. Some previous tech decided to pull all the higher power transistors for whatever reason and then lost some of them, didn't document what he did or anything resembling responsible work what so ever. This amp has some schematics up on the web but they are quite incorrect and incomplete, the +-15 volt regulator is completely missing as is the chassis wiring and circuitry.
I have reverse engineered a drawing detailing the missing circuitry and have done the same to the amplifier where I found that the schematics are pretty much worthless. Here's my tentative power supply schematic.
I have inserted values as good as I could read them from the board... I think I have it correct. Parts in question in this schematic have a question mark by them, it should be obvious what parts were missing, the two main transistors in the +-15 Volt regulator for one. Also there is a strange 15K ohm resistor where it appears a 1K resistor should be... there's been a lot of soldering, trace lifting and burning on this board so someone prior to me may have put that in by mistake.
Can anyone take a look and help me determine what parts should be where to make this thing work, my only alternative is to strip all that stuff out and put in a more modern dual regulator IC circuit, I'd really hate to do that however.
