Today my ceriatone JTM45 quit on me. After running it for an hour it just shut off. When I opened it up I saw the 2A 250v mains fuse had blown. HT fuse is still fine. No components looked burned. I checked the output tube screen resistors and both read fine.
I removed all tubes and the fuse blew immediately upon powering on (standby was still off). I checked the power transformer windings to ground with my multimeter and the primaries showed no reading at all. The 3.15 secondaries pair going to the pins 2 and 7 on V5 read .4 ohms, and the 350v pair going to the tube rectifier read 48 ohms. The transformers on this amp are made by Promitheus audio. Photo of PT attached.
I have a feeling the initial cause of all this is that one of the output tubes blew. The one suspect tube which I just swapped in a couple days ago has two large metallic ovals on the inside of the glass on opposite sides (see photos), is that a symptom of a KT66 which has overheated? I had another KT66 blow a ways back and it looked just like this.
Did a shorted tube take out my PT? What would be the next logical step in troubleshooting this?
