By high volume I mean with the chassis in the cabinet and a guitar signal turned up just to the point of distortion (LOUD). The crackle happens on the loudest part of the note played and may snap a half dozen times, always with the same intensity and sound. It does not happen with the chassis out of the cabinet.
I have re-flowed the solder on the control board and the main board. I have also swapped out the output transformer with a known good one. My next idea is to re-flow the solder on all the tube sockets and replace all the lug type connectors with soldered connections. If that doesn't do it then I'll replace the speaker cable and the wires to the speakers. My question is, has anyone else had a similar problem and know what fixed it?
