I have one of the old orange Roland Cube 40s that I was initially working on to solve the problem of no reverb. Turns out someone had replaced the reverb driver chip and installed it backwards, so I fixed that. Everything worked normally on the bench so I reassembled the amp to test it with a guitar. It played well for about a minute and then the volume dropped and the tone became very distorted. The sound I'm hearing is very similar to a pedal that has a dying battery. If you play very softly the signal is fairly normal but faint, but if you strum loudly the amp crackles and breaks up. I feel this is something obvious that I'm overlooking so I could really use some help.
Here is what I've diagnosed so far:
This pretty much leaves resistors and non-polarized low-capacitance caps. What does this sound like to you guys? Thanks.
- I've scoped the board and the preamp section is fine.
- All the transistors in the main section test okay.
- The voltage rails to the main section are what they should be +35V and -35V.
- All electrolytic caps have been replaced.
