Have an SL5 that comes on but volume just dies (maybe 1/2w) within 15 sec. It still has both channels (clean and od) working, just really low volume (not even like the 1w mode). Every once in a while it comes in regardless of 1 or 5w settings. Kind of a PITA to work on with the way the pre/output board is vertical. I was hoping to make working and non working voltage just for reference, but this just goes out too quick. It only seems normal when its really cold. I tried using freeze spray to bring it back to no avail. Pulled and inspected all boards, tube swap etc. Still acting up.
Problem has been reported on a few other forums, but no fixes indicated (just told to return). Not an option.
Voltages look ok based on what I would assume normal (plates grids cathodes htrs). Must be signal loss. Do these have relay issues? I would assume not the prob since I can get both Clea and OD, just the volume is really low.
SL5.pdf
Thx
SL5.pdf
Thx
