I have an Ampeg BA115HP bass combo amp that makes a popping noise whenever the amp is turned on or off. There is no DC voltage detected on the speaker terminal output. It will pass a signal to an 8 ohm speaker, but when I attach the stock speaker or anything else that's a 4 ohm load, it will see it as a short and the limiter bulbs would light up. Any suggestions?
Ampeg BA115HP speaker popping
1) popping is a fact of life.
Some take an extra pain to damp or kill it, some don't care.
Annoying but no big deal.
2)it will see it as a short and the limiter bulbs would light up
It will suck power (that's its job) , more current will pass, and bulb will shine brighter (that's its job) .
If amp works fine, plug it straight into the wall without the bulb limiter.Juan Manuel Fahey
Originally posted by goldtop5 View PostI have an Ampeg BA115HP bass combo amp that makes a popping noise whenever the amp is turned on or off.This isn't the future I signed up for.
When the amp came in for repair, the first thing it did was made a humming noise and the speaker pushed outward (and held that position) when the amp is turned on. I was throwing parts at it to see if the problem would go away. Eventually it did. But the popping noise still remained. I've read somewhere that these particular amps do that by nature. But the amp plays great now. It even pops when you hit the mute switch. I guess the customer will just have to live with that.
This is more of an FYI than troubleshooting assistance. I have had several of this model in the shop with bad filter caps. If I recall correctly 5600UF ?- the ones on the high voltage rails, whatever they are. I'm not saying it's a "common" problem, but considering that these are recent production models (in cap years), more cap problems than you would expect. I wonder if you have one of these starting to fail causing your +&- rails to come up unevenly. The hint is your statement, "When the amp came in for repair, the first thing it did was made a humming noise and the speaker pushed outward (and held that position) when the amp is turned on.". If you have a cap tester, it might be worth checking those caps."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
A speaker pushed out means DC on the speaker. if you lose a filter cap, you also get loud hum, but the speaker doesn't stay at max.
If your cold bias makes distortion, it is probably crossover distortion, which you can find on a scope of the output.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostA speaker pushed out means DC on the speaker. if you lose a filter cap, you also get loud hum, but the speaker doesn't stay at max...."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Dammit I want to beat whoever designed the chassis/cabinet over the head with one of these!
A tight fit, now the cage nuts popped off and its a pain to pop the one behind the power trans back in.
If I have to remove the PT to pop it in I'm gonna kill something
Obvious to some- not so much to others. So, excuse me for saying what some might consider obvious and stupid.
When you put in those cage nuts, put the tabs perpendicular to the direction the chassis slides in and out. If you put them parallel, sliding the chassis into the cabinet is more likely to pop them loose."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
The problem I find with those is that the chassis is so thin that when the mounting screws are tightened they deform the chassis, pulling the insert nuts out and in the line of the cabinet vinyl.
What I try and do is after the screw has been removed, use a thin straight blade screw driver to try and bent the metal back into place so that the chassis can be pulled out easier. And before reinstalling the chassis, I straighten out the chassis to make it easier to slide it back into the cabinet.
