Picked up a Mesa Single Rectifier Head today and need to make some repairs to get it working. I found the schematic here on the board which is great but it's not matching up with the circuit board.
Can anyone tell me the value of the resistor in the middle? Are these all rated at 1W? Thank you!
After replacing the resistors I'm going to install all new tubes, including the power tubes which I found damaged and replace the 20A fuse that was incorrectly installed with the correct 2.5A. I'm guessing that the first stage V1 tube failed and since the incorrect fuse was installed it did not blow and therefore heated up the resistors and the power tube.
