At this point I would stop doing anything to the amp until I matched up a good schematic. Got to trace it out a bit and figure out which version is a match. Then post that version of the schematic for us here too.
Marshall JMP MKII non master volume
Originally posted by pnut5150 View PostSorry for the confusion..I did use 220k ohm resistor
Can you alter the voltage on the power tube grid pins by adjusting the bias pot? If not, you need to repair the bias supply so it CAN be adjusted. I think what you have now is too much bias voltage or no bias voltage, depending on whether you have the resistor installed."Take two placebos, works twice as well." Enzo
Sounds like the bias is intermittently going to "full cold".
Some board flexing before may be why it straightened out for awhile.
Possible suspects are the bias trimmer, or bad connections at the bias trimmer or the 47K it connects to.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
It's a 150K for 6550 versions. But that is not necessarily what you have. Some one could have put 6550's in there.
Look at EL34 schematics and see if your circuit matches.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
The European versions with EL34's had 220k grid resistors, the us imports had 150k's for 6550's.
There are but minor variations of these amps from the plexi's until the the JCM800's.
its not rocket science, but a very simple tube amp.
I'd say pull the board out, carefully by removing the pots and check underneath for anything screwy.
Either the output tubes are flaky or the bias circuit isn't right.
Could be the diode breaking down, bias caps flaky or a flaky feed resistor.
He hasn't lost bias. It's either been biased full cold or working.
Except when he had the bias feed resistor removed and the tubes red plated.
Or when he touched the live circuit with the soldering iron. That's a major no no, could do severe damage or hurt yourself. Power down and discharge caps before touching the iron to anything.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
What voltage are you now seeing on the power tube grids, when idling with power tubes in?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
That's probably fine. What are your plate volts now?"Take two placebos, works twice as well." Enzo
Not to turn this into "20 questions" but here goes............Do you have a bias probe? If not, I recommend getting one if you plan to do much tube amp work at all- be it professionally or for a hobby."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
