Not against them bias probe ( ok, I confess, I am against them) but you are way beyond them, just solder a 1 ohm resistor from cathode to ground (instead of the wire which is there now) and measure voltage across it.
Please post results.
Bias probes don't do any better and add unreliable connections , who needs them?
I agree...mainly because I have a meter and dont need an extra unnecessary tool or expense. G1 said to measure DC volts across OT primaries and calculate current via that number and the OT primary resistance. Whats the difference between touching probes to measure DCV vs Current? I dont see one. To each his own. Ive been using the transformer shunt method for many years. I'm EXTREMELY CAREFUL and often choose to clip the leads on first. I didn't say the danger disclaimer because I knew if he was unfamiliar with this approach he would respond with HOW to do it. At which point I would make the danger clear and suggest the clip-lead method. Really if one is concerned use the 1ohm cathode method. Just be sure they are within tolerance and be sure to compensate for the reading when simply shorting probes together.
